OBDII codes came up... need assistance please....
<b>Info</B>: 1998 A4 1.8T.
<b>History</B>: stumbly start a couple times, check-eng came on a few times, then stayed on, and today the car refused to start for a while, but did eventually.
<b>Codes</B>: P0118 -- Eng coolant temp sensor ckt high input.
<b>Pending code</B>: P0332 -- Knock Sensor 2 ckt low input (bank 2).
So now what? How can I test these sensors? I ordered the Bentley CD, but in the meanwhile, I have to drive 75 miles away every day, and I'm a bit nervous to do so.
Thanks,
-Neil.
Thanks,
-Neil.
well.
due to your commute, just in case you don't
already, I suggest you check your oil at least
once a month.
next, knock sensor... sounds like bad gas,
try higher octanes whenever possible.
coolant temp sensor... dunno, maybe your temp
sensor needs to be replaced?
once a month.
incorrect, wasseem. Try this. Bank 2, on a 1.8T???
There's only one bank on a 4 cylinder! Your problem is the engine coolant temp sensor(ECT sensor). it's sending either a high or low signal at start, leading the ECU to believe it's already warmed up, and feeding it fuel respectively. This causes a hard starting/stumbling problem. Replace it, clear faults, set basic settings in group 060, and see what it does. I doubt you'll see the knock sensor fault again...
89 because...
Always used 92, but heard that Audi specified 89 minimum. Since I'm only doing the non-performance 150-mile round-trip lately, I figured I'd scale back for improved gas mileage, and the knock sensor system would keep me safe. Besides, I've been unemployed for a couple months now. :-)
blackbart
11-01-2006 02:19 PM
rd350
05-07-2005 10:22 AM
mtmOla'
VAG-COM Discussion
10-22-2004 05:48 PM
