I'm getting a single click when I lightly touch the brakes...
Old Jun 4, 2003 | 08:28 AM
The Red October's Avatar
Default I'm getting a single click when I lightly touch the brakes...
I have the stock calipers and carriers, powerslot rotors, hawk HP+ pads in the front, hawk HPS in the rear, and SS brake lines.
A few weeks ago I swapped out the OEM rotors and pads and put the powerslots and hawks on for a track event. At that time I did not use any disc brake quiet compound. A was getting a faint popping noise from the front driver's side caliper when apply or releasing pressure from the brake pedal, wether the car was moving or not. Just a slight change in pedal pressure would make it pop.
Last week I took it apart, I discovered that the 3 prong spring on the inboard pad was loose, allowing it to move around a little inside the piston. I stretched it out a little so it was a tight fit, did the same thing to the other side of the car, and put permatex on the outboard pads.
That helped stop the squealing alot, but now I get a single click when I apply the brakes. Almost sounds like a small rock is thrown up and hits the wheel well liner. I can just barely feel it in the brake pedal. It does not click every time I hit the brakes lightly, but it does seem to do it more often when the car has been sitting for a while and the brakes are cold.
Any ideas what this is? Is it a normal noise? The pedal is nice and firm and the car stops very well.
Does the permatex hold up well? The it seems like the car is starting to squeal more than right after I put the permatex on.
Old Jun 4, 2003 | 08:36 AM
WJM's Avatar
WJM
Tech Guru
pads are rattling around that's all
Old Jun 4, 2003 | 08:55 AM
skabaru's Avatar
Default I have the exact same problem with the same pads... nothing big...
the passenger side pad rattles a bit... I haven't had any issue with it... I too took it apart and tried to adjust the prongs but to no avail. oh well.
if you hit a solution worth doing, post.
DoubleA4
Audi allroad
Sep 10, 2013 05:47 PM
Swank4
9
Jul 25, 2007 03:12 PM
ScottJ
Mar 31, 2005 12:11 PM
actionman
Nov 5, 2002 06:46 PM
mdwsta4â„¢uroslut
Apr 16, 2002 08:08 AM
