Shifting problem
Old Oct 17, 2001 | 05:44 PM
pwhatley's Avatar
New Member
Default Shifting problem
I have a 1987 4000S and it won't shift into 5th gear. This occurred after I picked it up from having rear brake shoes put on. I had no problems before I took it to the shop. The shift lever will go in to the 5th position,but the trans is actually in third. The trans goes from 1 thru 4 just fine. Does anyone know what's causing this?
Thanks
Old Oct 17, 2001 | 08:01 PM
Lurk'n's Avatar
Junior Member
Non Quattro eh?
Old Oct 17, 2001 | 09:42 PM
Evol's Avatar
sounds like shifter bushings
Old Oct 19, 2001 | 03:05 AM
Dwight V.'s Avatar
Member
Default Re: Shifting problem
My web site has pictures of the two types of shift linkages. May want to have a look and see which you have.
Seems odd that 5th would be a problem but not reverse too?
If you have the 'early' style I illustrate (which may be common to 4cyl cars regardless) the bushings can disintegrate and fall out when they get old. They are available seperately. If you need them, let me know and I'll get you the part numbers. I forgot to post them on the site.
Old Oct 19, 2001 | 05:39 PM
80'sAudiguy's Avatar
New Member
Default My experience with this is...
If you are in need of shifter bushings for your '87 4ks, the dealer may not have the bushings, but will be quite willing to sell you shifter bracket (with bushings pre-installed) for $40 to $50 each (takes a left and a right side to make this work).
However, the exact same bushings are used in the VW Fox, and those bushings can be bought separately from the dealer. I think I spent $15 or $20 total for all the bushings last time, and the shifter then felt BRAND NEW!.
The most common failure, however, is the one bushing that fits over a ball on the left bracket onto which a rod connects to the tranny to provide the pivot point for the linkage. This "cup" bushing is maybe $4, and that is probably all you need to get all the gears engaging again.
Once you take a look under the car and find the shifter linkage, it should become apparent as to the procedure for r&r'ing the bushings.
Let me know if you need help,
-- Tom
Old Oct 21, 2001 | 08:43 AM
pwhatley's Avatar
New Member
This site is great!! I know someone out there would
have an answer. I'll let know if need any more help
after I get everyhing broken down. Thanks again.
Old Oct 21, 2001 | 08:51 AM
pwhatley's Avatar
New Member
Default Re: My experience with this is...
Thanks Tom! Sounds like a simple procedure. I take it that this repair is done from underneath the car?
I was thinking that I had to take the shift boot off
to access the bushings.
I'll let you know if I have any questions.
Old Oct 24, 2001 | 06:54 PM
pwhatley's Avatar
New Member
Default Problem solved...for now.
I had a mechanic friend check the problem out and he couldn't find were the bushings were located. He didn't fix the car. I picked the car up and decided to take the shift boot off and see what was going on.I removed the retaining plate also.I moved the lever through the gears a few times,replaced everything and the car shifted as normal. Can't explain that! Maybe something was binding.
Thanks everyone.
 Pouria Savadkouei
 Michael S. Palmer
Rolf
Oct 1, 2006 12:20 PM
OdorCide
Aug 4, 2005 07:03 PM
quattromano
Mar 8, 2004 10:54 AM
unipurify
Aug 21, 2003 03:04 AM
krayziekujo
Aug 29, 2002 07:09 AM
