Wierd?!?!
Old Nov 29, 2001 | 08:29 PM
1hot4000s's Avatar
New Member
Default Wierd?!?!
k my cars battery meter is getting really low and when i hit the gas too rev the motor it goes up and then when it sits for a bit it goes back down!??!?!! is this a alternator or a batery or what?!?! any help is apreciated thx
Old Nov 29, 2001 | 09:14 PM
VeDubShark's Avatar
New Member
Sounds like a battery problem... also could be a voltmeter problem
Old Nov 29, 2001 | 10:06 PM
Evilclown's Avatar
AudiWorld Uber User
Default It's probably the alternator diode gone bad.
If that's the case, it's easier to replace the whole unit, since the diode is inside the case, and alternators aren't much fun to take apart. Also, pull the voltage regulator out and check the brushes, if they're worn too badly they could cause that.
Old Nov 30, 2001 | 03:55 PM
Chris in VA's Avatar
Junior Member
Default Easy fix
Voltage regulator. Undo the 2 bolts on the alternator and simply pull it out. The brushes are probably worn down. I have no idea how much these cost though...
Old Nov 30, 2001 | 07:46 PM
Evilclown's Avatar
AudiWorld Uber User
Voltage Regulators are cheap, maybe $30 max at any parts place.
1999Audi
Dec 11, 2010 05:06 PM
Fast Euro
Aug 5, 2006 04:10 PM
audido
Feb 6, 2006 09:22 AM
delta v
Apr 6, 2005 02:34 PM
Bidwellian
Audi 100 / A6 (C4 Platform)
Dec 22, 2003 07:49 PM
