Headlight wiring looks like it's melting
Had a headlight (DS) go dim on my 86-4KQ and when I opened up the area around the bulb to check the plug, I found that the ground (brown) clip in the socket is a dark brown and looks like it's melting.
I took the other side off and it looks similar, not quite as bad. The switch doesn't seem to get overly hot when using the lights, so I don't know what would cause it to happen at the plug/bulb connection.
Any ideas??
Jon
Mike
85 4000S
I will put in a seperate ground and see if it improves the situation.
Jon
