taking off door panels
Thanks for any help
Remove the armrest, two screws, then twist it vertical and pull out the stud that is in the end of the 'handle' part.
If you have pwr mirrors, getting the plug on and off the switch inside the handle absolutely SUCKS.
Remove the map pocket from the door panel (probably already falling off from the plastic breaking). About 8 screws hold that on, some may be a little hidden by the carpeting.
Remove any other visible screws. Pop the little cap off inside the door handle and remove that screw.
Remove the cap and screw that holds the mirror trim piece in place.
With a quick, firm yank, pop out the clips that hold the panel to the door itself around it's perimeter.
Pop the panel off at the top. The plastic molding has clips in it that keep it to the door. This can sometimes be a PITA.
Remove the rod from the door handle (it just loops in a hole).
I think that's it. Installation is the reverse of removal.
Sorry about all the questions, its my 1st Audi and i dont wanna screw it up
I don't think undoing the mirror cover or the side pocket is necessary. You shouldn't have to take the plastic trim off the top either. The panel should slide out of it's groove.
sorry about the caps my woman was on the computer again just realized it not about to re type !
