how do u remove door panels?
not positive on our cars..
usually their is 3 screws, one behind the doorhand lever, one inside the cup holder, and usually one around the little pocket at the bottom..Also open the door and look around the edges for screws.
Then pull around the side and bottom edges to un do the pins/clips. Once all of those are undone pull up and it should come undone, then un hook the lever, and the lock assem.
Again im not sure on our model, but others its like this. Good luck
inside>>>
there are two screws on the top corners of the panel, remove those (one facing out toward the street and one facing in toward the engine bay). Then remove the screw at the door handle and remove that plastic cover, there is another screw behind the cover that needs to be removed. With those removed you can lift the door panel up and it should pull away. Be careful not to pull it too far away from the door because there are a lot of electronics still connected. Trick putting it back on is making sure the lock/unlock deal on the top by the window is lined up with the hole.
really simple
really simple
Ant 12v
04-06-2003 06:50 PM
jyoteen
03-18-2003 11:02 AM
kilburn
06-23-2002 01:14 AM
