How to identify a solid lifter head?
Thanks,
valve spring. If this is the one from Ebay few weeks ago it is a solid lifters head, but again check ignition distributor mount.
Going back to solid or hydraulic lifter - in opening were valve lifter is moving up and down on the top of valve assembly you will have at list one oil jet in side wall to supply oil to hydraulic lifter. There are also some times two jets connected via grove cut in side wall. In case of solid lifters holes for jets will be pluged.
I hope this help.
272 cam is very mild cam for Ur Quattro. If ignition distributor checks out OK remember to readjust valve clearance after you change cam shaft. It is not bolt on swap. I also strongly suggest to check valve clearance and readjust if necessary after about first 1000 miles.
Good Luck.
Thanks
I know that old short distributors are very hard to find. Do not know or can be modified to work with Hitachi Ur Quattro ECU. I belive that pick-up inside sends 5 signals per revolution insted of one.I hope this explains.
I am told that KH hydro heads off 84-85 5000 Turbos bolt right up to WX blocks. Any day now I should be able to confirm this since that is what is sitting in my garage waiting impatiently to go.
Re: reground cam to fit solid lifter heads, I think solid lifter cams may have a bigger base circle than hyrdro cams, so if you have a regrind, you will likely have a smaller base circle. As a result, you will have to tighten up the valves a bit.
Thanks for all the great input
At the high end, it may very well work great. That's what I'm hoping for. At the very least I'll have a cool lumpy idle!
There was quite a debate on this exact topic over on motorgeek a while ago. You might want to take a look. And the "winner" seemed to be the stock cam, MC in that case.
BUT, when talking urqs, the WX cam is known to be an emissions cam. The Euro WR gained 40hp on the North American WX by having a more aggressive cam, no cat, and maybe a slightly tweaked ECU.
WR cam should be a good, proven way to go if you can find one.
But I'm going with the 272 anyways.....
