The adjusting screw in the top front of the throttle
Old Oct 31, 2005 | 11:50 AM
Mike Desi's Avatar
Default The adjusting screw in the top front of the throttle
body fell out on my way home tonight. Thought it was a Halloween prank because of the rather loud whistle noise it made. Are they available? And what would happen if I just put a bolt in it for now?
Old Oct 31, 2005 | 12:11 PM
Katman's Avatar
Default Bolt wont work..
I too had that same problem.
Fell out, and the craziest noise!
Ended up puttting a dab of silicone goop over top the adjuster, so it won't come out again.
Problem is, a bolt won't have the pointed tip that the adjsuting screw has. THe bolt will stop the noise, but you'll probably still have a really high idle.
FYI: The adjuster from a MC motor won't work in a URQ intake maifold either! It'll fit, but it won't adjust the idle airflow..
Old Oct 31, 2005 | 01:06 PM
Tony@EPL's Avatar
Former Vendor
Default they are avalible....but my dealer wanted like 28 bucks for it =).
I used one out of a VW fox... 2 bucks if I remeber correctly.
Old Oct 31, 2005 | 06:14 PM
audiurq's Avatar
New Member
Default Re: they are avalible....but my dealer wanted like 28 bucks for it =).
I put one of those rubber boots over the
idle screw after it happened to me. I figured
at least that would catch the screw and stop
it chipping the bonnet.
Old Nov 1, 2005 | 04:30 AM
racingiron's Avatar
Default $28? Looks like list is just over $5.
035 133 432 right?
Old Nov 1, 2005 | 06:16 AM
urq20vt's Avatar
Default Huh?
Standard dealer 500% markup perhaps?<ul><li><a href="http://www.worldimpex.com/search_by_partno.html?searchmode=partno&amp;partno =035+133+432&amp;x=36&amp;y=1">Get it here for $4.66</a></li></ul>
alternety
Feb 28, 2009 04:08 PM
GDawgA4
Oct 6, 2006 05:02 AM
drchad
Jun 29, 2005 08:57 PM
STTASH
Jun 18, 2003 04:21 PM
BoostFrenzy
Nov 13, 2002 10:10 PM
