The adjusting screw in the top front of the throttle
body fell out on my way home tonight. Thought it was a Halloween prank because of the rather loud whistle noise it made. Are they available? And what would happen if I just put a bolt in it for now?
Bolt wont work..
I too had that same problem.
Fell out, and the craziest noise!
Ended up puttting a dab of silicone goop over top the adjuster, so it won't come out again.
Problem is, a bolt won't have the pointed tip that the adjsuting screw has. THe bolt will stop the noise, but you'll probably still have a really high idle.
FYI: The adjuster from a MC motor won't work in a URQ intake maifold either! It'll fit, but it won't adjust the idle airflow..
Re: they are avalible....but my dealer wanted like 28 bucks for it =).
I put one of those rubber boots over the
idle screw after it happened to me. I figured
at least that would catch the screw and stop
it chipping the bonnet.
Huh?
Standard dealer 500% markup perhaps?<ul><li><a href="http://www.worldimpex.com/search_by_partno.html?searchmode=partno&partno =035+133+432&x=36&y=1">Get it here for $4.66</a></li></ul>
STTASH
06-18-2003 04:21 PM
BoostFrenzy
11-13-2002 10:10 PM
