I'm pissed......On the way to the dealer to pick some parts up and
However, touch-up paint <B>can</B> look good <B>if</B> you do it right. Most people just don't take the time. One option is the LANGKA paint chip repair system ( <A HREF="http://www.langka.com/">http://www.langka.com/</A> ). The other is this method:
"Carefully fill it in with your touch-up (leaving a blob), let dry only 15-30 min and then apply 3M imperial hand glaze to piece of cotton T-shirt and wrap around something flat (I used a cut out piece of an old credit card). Rub this on the touch-up blob, keep adding more IHG, and it will slowly wear away until it is flush/smooth with surface. This is similar in principle to the Langka method. I've done a couple of these on my car and was amazed by the results." - DarinS4Turbo
