Wheel bearing problem on my 2003 A4 3.0
Old Aug 30, 2003 | 09:35 PM
cyberdrive's Avatar
New Member
Default Wheel bearing problem on my 2003 A4 3.0
Has anyone had any problems with wheel bearings on 2003 A4 models. Since my car reached 1,200km, it started making a noise in the front. It has continued to make more noise...driving me crazy. The dealer believes it's a bearing problem, but they didn't have any in stock when I went in. Will be going back when stock arrives and hopefully the problem will be solved.
Old Aug 31, 2003 | 11:37 AM
Bob Petruska's Avatar
25 Year Member
Default Swerve the car back and forth at low speed in a parking lot....
The bearing noise should be very noticeable in one direction and not the other. The swerving causes bearing loading and unloading. If the same noise is in both directions...then I would question a bad wheel bearing diagnosis!
Old Aug 31, 2003 | 12:32 PM
cyberdrive's Avatar
New Member
Default Re: Swerve the car back and forth at low speed in a parking lot....
thanks Bob for your reply. I will try the swerving tonight. If the same noise appears, any idea what could be the problem. Essentially, it sounds like I'm driving with winter tires and every so often, there's a vibration in the gas pedal, at around 100kph.
SchwarzY2kS4
Want To Buy - Archive (NO NEW POSTS HERE)
Nov 19, 2015 04:53 PM
krazyhabu
Q5/SQ5 MKI (8R) Discussion
Sep 30, 2015 03:01 PM
imag1ne
A6 (C7 Platform) Discussion
Sep 28, 2015 01:05 PM
csongi86
Sep 21, 2015 12:24 AM
mikel102
Sep 18, 2015 05:27 AM
