KW V2 Questions...
Old Aug 31, 2003 | 01:43 AM
IWantMyRS4's Avatar
Junior Member
Default KW V2 Questions...
What setting do you have it on?
Is this a sedan or avant?
What kind of driving do you do?
How low did you go?
What kind of roads do you drive on? Smooth freeways, crappy, potholed San Francisco Roads, etc...
What size wheels/tires are you on?
Old Aug 31, 2003 | 01:17 PM
StratAirZ's Avatar
Elder Member
Default I'm assuming your asking anyone with these on their car, so...
1. they are on the out of the box settings
2. sedan
3. I drive more agressive than most
4. can't go any lower with out rubbing on the rear with four people in the car on bumps.
5. I drive on all the above, right now I'm in OK city, and the roads here are hell.
6. I have 19" 235/35/19
I have pics on the poster. If your thinking of getting these, you should. I love them they ride very nice.
Questions?
Old Sep 1, 2003 | 01:46 AM
IWantMyRS4's Avatar
Junior Member
Default Re: I'm assuming your asking anyone with these on their car, so...
Awesome, exactly what I was looking for : )
Is there a reason that you didn't change the rebound settings? If it was easier to change it would you now? If so to what setting?
BTW, the way those wheels sit on your car is EXACTLY how I want mine to look. I assume you have a 35mm ofset?
Old Sep 1, 2003 | 07:29 AM
StratAirZ's Avatar
Elder Member
I guess if it was easier to make changes to them I would stiffen the dampening on the rear just a bit, they seem just a bit softer than the front, but not worth the work to fix it. I did need a second adjustment for ride height. they settled probably 1/4 inch. So either set them a little higher than you want or get the adjustment and alignment included in the install price, the shop that did mine did the second setup for free. As far as the offset, yes 35 and that is the perfect offset. The wheels will tuck but just barely.
a4neil
Jun 25, 2002 08:52 AM
got_root?
Aug 10, 2001 03:50 PM
WSP2001
Jun 6, 2001 09:11 AM
BRK
May 16, 2001 08:17 AM
The Bald Marmot
Oct 25, 2000 09:08 PM
