Fault code help
Old Jul 25, 2004 | 03:37 AM
teutonic blur's Avatar
New Member
Default Fault code help
ok geniouses, I'm getting the following code:
VAG-COM Version: Release 311.2-N
Control Module Part Number:
Component and/or Version: 1.8L R4/5VT G01 0003
Software Coding: 0016501
Work Shop Code: WSC 63351
1 Fault Found:
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal - Intermittent
I clear it and it comes back after 4-6 weeks.
I know it's related to an O2 sensor going bad or problems with the sensor wiring and that it probably isn't serious.
My next scheduled visit to the dealer is a couple of months away. Is it safe to wait a couple of months or should I take it in earlier?
TIA
Old Jul 25, 2004 | 06:03 AM
alipor's Avatar
Default Are you chipped?
if so, I get this code. I have talked it over with my tech. It might not be the wiring, it could be that the heaters stay on when they shouldn't be and overheating the sensor thus the internal resistance too high.
Old Jul 25, 2004 | 07:28 AM
New Member
Ye, I have Revo. I guess if it was something serious I would get a light so I'll probably wait.
Old Jul 25, 2004 | 07:38 AM
alipor's Avatar
Default well If you are getting this code, I would check your lambda readings
to see if you are running lean. If you let the codes sit long enough I guess you will get a code the more they pop up. Or you might never get a cel.
Old Jul 25, 2004 | 08:15 AM
New Member
Good point. I'll check those readings. Thx.
DanD.
A4 (B8 Platform) Discussion
10
Nov 25, 2016 03:35 AM
subterFUSE
S6 / RS6 (C7 Platform) Discussion
Sep 22, 2015 05:06 PM
csongi86
Sep 21, 2015 12:24 AM
tmac2015
Sep 20, 2015 04:29 PM
ericliquid
Sep 17, 2015 06:13 AM
