Need Help!!! Installing Thermal Exhaust....Trying to Remove Stock Exhaust from Rubber Hangers.....
Old Jul 25, 2004 | 06:00 AM
Bolo's Avatar
Default Need Help!!! Installing Thermal Exhaust....Trying to Remove Stock Exhaust from Rubber Hangers.....
Presently in the process of installing my Thermal Street Exhaust system.Got the car on ramps & stands ...I managed to unbolt the the downpipe already...
But the Real Bugger are the middle Exhaust rubber hangers supporting the center split pipe....how did you guys managed to slip out the stock exhaust hanger stem out of the rubber support? the stems on the stock exhaust has a buldged end to keep it from slipping out of the Rubber hanger.....Did you guys managed to muscle it & pop the stem out of the rubber piece...or better just to sawcut the stock exhaust stems off???
Old Jul 25, 2004 | 06:04 AM
slugo10's Avatar
New Member
Did you try somw WD40 on the rubber to slip it out?
Old Jul 25, 2004 | 06:14 AM
Bolo's Avatar
Yup...I only managed to slip a screw driver in the slot but still not succesful on popping it out...
Old Jul 25, 2004 | 07:11 AM
Audi2ptzero's Avatar
Elder Member
Default Did you remove the whole exhaust system by removing the bolts
holding the hangers to the car?
Old Jul 25, 2004 | 09:06 AM
Bolo's Avatar
Default Dit it!...Dang! that was a B*tch....used WD40 & skinny screw driver to twist & pop them out.
<center><img src="http://pictureposter.audiworld.com/38085/mvc-004f.jpg"></center><p>
And the Stock exhaust is real pig heavy.......Now I'm only halfway done....hopefully installing the Thermal is alot easier...
Old Jul 25, 2004 | 10:06 AM
Tsle's Avatar
Yeah, getting the stocker off is a PITA.
Old Jul 25, 2004 | 07:08 PM
LAS's Avatar
LAS
the stock exhaust is one piece right? what are you planning to do with?
Old Jul 25, 2004 | 08:59 PM
Bolo's Avatar
Not sure....kept it just in case I'd sell my car one day.
 Pouria Savadkouei
 Michael S. Palmer
IntheQ5
Q5/SQ5 MKI (8R) Discussion
38
Oct 21, 2024 10:43 PM
xkahn
Feb 8, 2018 10:43 AM
ECS Tuning-Audi
Sep 1, 2015 12:25 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
Sep 1, 2015 09:16 AM
ECS Tuning-Audi
Sep 1, 2015 08:27 AM
