Suspension guys ...HELP
Old Jul 26, 2004 | 05:49 PM
keede's Avatar
New Member
Default Suspension guys ...HELP
I am about to buy these neuspeed quattro sport springs from this guy for my FWD....I know rear
springs for quattro are .5" longer but I heard that they will still fit my FWD and even should be better b/c neuspeed
springs tend to sit lower in the rear. By putting the quattro springs on my fwd, this should eliminate that problem and give you a much more balanced look.
I emailed Supreme Power Parts and they said that
they will fit with no problem
BUT
I emailed Neuspeed about it and they said
" Unfortunately, this is not true. The rear springs for a FWD and AWD are completely different so they are not interchangeable."
What do U guys think??? What should I do
Is there anyone that did that and have no Problems???
thanks
Old Jul 26, 2004 | 05:58 PM
bhvrdr's Avatar
I'd give Mike at Purems.com a hollar. He's had no probem running quattro springs on fwd cars.
Old Jul 27, 2004 | 04:18 AM
HighPSI's Avatar
Default They'll work fine, they are probably a stiffer spring rate and a little longer so in Neuspeeds eyes
they are completely different so that they will hopefully sell another set of springs to you
Old Jul 27, 2004 | 08:32 AM
Matt Devo's Avatar
2nd
Old Jul 27, 2004 | 08:43 AM
HighPSI's Avatar
Default matt, how are your street sports?
i get a weird scraping/clunking sound in the rears if the back end bounces hard and im thinkin the perch that the spring sits on might be movin slightly up and down since i had trouble gettin the set screws to bind down real tight, you havin any similar problems? If this is the problem, you think taking out the set screws and actually "bolting" that lower perch in with some screws through the holes where the set screws go in would be a reasonable solution?
Pmpsch
Q7 MKII Discussion
14
Dec 6, 2015 01:14 PM
cclsvtf
Q7 MK 1 Discussion
Sep 12, 2015 01:06 PM
ZPA117
A4 (B8 Platform) Discussion
Sep 8, 2015 11:55 AM
wjhpilot
S4 (B8 Platform) Discussion
Sep 4, 2015 01:43 PM
kevf95
Canadian Discussion
Sep 1, 2015 04:34 PM
