n75j works, with apr 1+, 2003 1.8t
now, i say the n75j works fine right now w/o issue, but i guess it could still make me overboost at some point, but i've been lovin every minute of it on 100 oct. noticeable diff.
install- not too bad, a little pain in the *** getting the small clamps off the hoses and getting new clamps on and getting the hoses on the new n75j...also, the wiring harness that connects to the n75 is not long enough for the n75j as it is oriented differently and the connection point faces the opposite direction than the original..solution- you have to cut the wrap around the wires that connect to the n75 and the maf enough so that you can reroute that wiring harness in a more direct fashion...
all smiles so far
imo, you might as well try it, its only $75 and im sure you could change it easily<ul><li><a href="http://www.impexfap.com">http://www.impexfap.com</a</li></ul>
