PP 8500 hardwire installation help
Old Sep 27, 2004 | 06:39 PM
kamran_audi_baz's Avatar
New Member
Default PP 8500 hardwire installation help
(For reference I have a 2003 A4 1.8T)
I know there are tons of posts/articles on how to hardwire the 8500/V1. I've looked through most of them and have gotten a very basic idea on how to do it. I think the best way to do it(or it seems that way to me) is to bring the wire down the A-pillar into the fuse box.
I just have some questions and would greatly appreciate if someone would take the time to answer them.
1) How exactly do you go about opening the fuse-box door?
2) I noticed one of the articles saying to use fuse #27, and another #25? Which one would it be?
3) From my understanding, the 8500 hardwire that you purchase from Escort comes with a 'spade connector' that you can just 'plug in' directly into the fuse, if I'm not mistaken(after you ground it of course into the screw at the bottom of the fuse box?). Is this correct?
Am I missing anything critical?
Thanks in advance.
Old Sep 27, 2004 | 06:53 PM
Eddie Man's Avatar
Default Some Answers...
1. Look at the fuse door...There is couple of detents on the edges...Just use your door key there to pry open there...Not hard at all.
2. Not sure which one but this is the one I used...It is switched "on" w/ the ignition.
<img src="http://images.snapfish.com/33%3B33%3C3923232%7Ffp63%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232358547%3C295ot1lsi">
3. Yes.
Missing anything critical?...Not really, but make sure you fuse your detector seperately and you should be all set.
Hope this helps
Old Sep 27, 2004 | 07:02 PM
New Member
Default Re: Some Answers...
Thanks for the answers!
Just one more question, what do you mean by 'fusing the detector seperately?'
Thanks again!
Old Sep 27, 2004 | 07:08 PM
Eddie Man's Avatar
Default Anytime you "tap" a fuse or fuse box, you need to...
protect that equipment you just attached...That equipment needs to be "fused seperately" with some sort of in-line fuse...This is usually provided in some form w/that equipment...Either in a cigarette lighter plug or in a hardwire kit...If not, get one at Radio Shack...They can help you w/one.
Old Sep 27, 2004 | 07:28 PM
HX_Guy's Avatar
Default Do you have Platimun (gray) interior? If so, buy my custom hardwire remote...
<img src="http://members.***.net/valentinberechet/PassportRemote.jpg">
<img src="http://members.***.net/valentinberechet/8500Install%20068.jpg">
I did a picture-by-picture install here a while ago as well.
Old Sep 27, 2004 | 07:35 PM
HX_Guy's Avatar
Default Step-by-step instructions *Picture version*
https://forums.audiworld.com/a4gen2/msgs/670810.phtml<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/670810.phtml">Click here.</a></li></ul>
xkahn
Feb 8, 2018 10:43 AM
AlllRoad
Sep 15, 2015 12:51 PM
ECS Tuning-Audi
Audi A3 / S3 / RS 3
Sep 11, 2015 11:56 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
Sep 1, 2015 09:16 AM
