Anybody have a clicking/tapping sound from the front suspension *coilover owners*?
Old Sep 28, 2004 | 03:18 AM
PimpluxA4's Avatar
Junior Member
Default Anybody have a clicking/tapping sound from the front suspension *coilover owners*?
I have a set of TEIN Basic coilovers and they click/tap sometimes when you hit a bump. We removed all parts, re-installed rubber boots, put all rings/seats back but the sound prevails. H&R and KONI owners have this problem too? Please post up! Thanks, Mike
Old Sep 28, 2004 | 05:03 AM
sj audi's Avatar
Default mine is more of a clunkish tap
but its not from the rubber hat not being tight enough.
it only happens on atlanta roads, i don't get it when i'm on smoother roads back up in md.
mine did start squeaking tho... gotta look into that this weekend.
Old Sep 28, 2004 | 07:30 AM
gimp2.7's Avatar
Default is it slammed? my driver side rear does that sometimes because the car is soo low that the....
springs dont touch the bottom O ring. just adjusted the placement of the sring and problem solved
Old Sep 28, 2004 | 07:40 AM
JsprZ's Avatar
maybe it's the swaybar links?
Old Sep 28, 2004 | 04:25 PM
Nammo's Avatar
Junior Member
Default my KW V1 coilovers produce a clunk sound
at low speed turns.
Have been in contact with KW North America, they have not been able to provide an explanation.
Very annoying.
Old Sep 29, 2004 | 01:48 AM
icecool's Avatar
New Member
Default Re: Anybody have a clicking/tapping sound from the front suspension *coilover owners*?
Your spring is bouncing/moving about its seat.
Old Sep 29, 2004 | 09:36 AM
sj audi's Avatar
Default thats what i'm pretty sure mine is too
doesn't seem to me to be anything super serious, but i'm not suspension guru.
any way to reduce the movement?
Old Oct 1, 2004 | 06:29 PM
icecool's Avatar
New Member
Default Re: check the coil seat.. sometimes the tip climbs the little notch and 'falls' back down..
.. when it rotates around the shocks..
Another way is to fasten the spring to either end so it doesn't bounce around when you're taking hard corners... try strong nylon cable ties.
Good luck..
 Pouria Savadkouei
 Michael S. Palmer
LaserSVT
RS 6 Discussion (C5)
Jul 22, 2022 10:29 AM
xkahn
Feb 8, 2018 10:43 AM
ohsigmachi
Mar 29, 2016 05:04 AM
Jan_PL_S6
12
Nov 27, 2015 07:27 AM
ZPA117
A4 (B8 Platform) Discussion
Sep 8, 2015 11:55 AM
