After ECT swap and replacing some coolant...heater sometimes blows cool air...(more)
Old Mar 13, 2005 | 08:19 AM
fourwheelslide's Avatar
Member
Default After ECT swap and replacing some coolant...heater sometimes blows cool air...(more)
Lost a fair amount of coolant when I replaced my ECT sensor and it popped off...replaced the coolant and redid the sensor, now when I use the heat, it doesn't seem as hot as it used to and sometimes will even blow cool air, especially on the passenger side. Thoughts? Do I maybe have air in the coolant system? I noticed the expansion tank bubbling a little, but VAG has coolant temp at about 205 degres Fahrenheit (96 celsius). I know that excess air in the system can cause an early boil, but i did a 60/40 solution per the manual, so it should be good to 250+ fahrenheit.
Old Mar 13, 2005 | 12:22 PM
Ultrasport-Sal's Avatar
Junior Member
Yes, it sounds like possible air in coolant.
Old Mar 13, 2005 | 01:14 PM
Member
Default I bled the line at the bleeder valve under the engine cover...
...still cold...do I need to do more than one bleed...I ran the engine until coolant began to come out of the bleeder hole and then capped it. Anything else I should know or try?
LaserSVT
64
Jan 19, 2016 04:26 PM
raiderrider
12
Sep 8, 2015 05:46 AM
CPLYONS
Sep 7, 2015 07:19 PM
anticsAK
Sep 6, 2015 05:34 AM
anticsAK
Sep 4, 2015 09:59 PM
