How do you get the ECU screws to budge????
Old Mar 13, 2005 | 09:49 PM
gaogi's Avatar
Default How do you get the ECU screws to budge????
I used a dremel to cut a slot on the screws, but those darn thread lock glue that they used makes it impossible to turn the screws! Anyone have some tricks to remove these screws? I'm about to go to Home Depot and buy a screw extraction kit...
Old Mar 14, 2005 | 04:07 AM
Jet Jockey/A4 Pilot's Avatar
I assume you mean the ones that are locked in place with plastic. Heat them up.
Old Mar 14, 2005 | 04:40 AM
A4 Moda's Avatar
Junior Member
use your teeth.
Old Mar 14, 2005 | 06:38 AM
shadyraven's Avatar
Senior Member
You need more leverage - use a socket driver with a flat-head bit.
Old Mar 14, 2005 | 10:02 AM
ben gt/cs's Avatar
Default off APRs website
<ul><li><a href="http://www.goapr.com/Audi/support/ecu_a4_b6.pdf">PDF format instructions</a></li></ul>
Old Mar 14, 2005 | 12:50 PM
gaogi's Avatar
Already got past all that...it's getting past the thread lock glue that's giving me problems
Old Mar 14, 2005 | 02:26 PM
alipor's Avatar
Default I ended up using Vice grips to take mine out for the 3rd time
there is just enough room to get vice grips on the screws so you can turn them.
Old Mar 14, 2005 | 04:40 PM
gaogi's Avatar
Tried that too...now my screw is all mangled up, and they still haven't budged.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 14, 2005 | 05:00 PM
A4 Moda's Avatar
Junior Member
Did you try Jet Jockey's Advice? Good Luck BTW
uble1234
14
Oct 23, 2020 08:07 PM
Kerry G
May 18, 2018 06:12 AM
A6GT
A6 (C7 Platform) Discussion
17
Dec 29, 2016 08:15 AM
brjones
A4 (B8 Platform) Discussion
16
Oct 7, 2015 08:17 PM
Force-1
Q7 MK 1 Discussion
Oct 7, 2015 05:15 AM
