seeking major help PC crash
So try to reset the board first. The Jumper settings are in the board manual, inclusive the reset procedures.
Good luck!
1.) Open up the computer case
2.) Look at the power connector going into your CD drive. It is a white connector with a set of 4 thick cables (yellow, black, black, red)
3.) Look for a receptacle on the video card that looks like it can fit one of these connectors.
4.) If you find this on the video card, locate an unused power connector and plug it in
This should fix you right up. If not, then find your nearest computer geek and have them inspect it.
Cheers!
<img src="http://images16.fotki.com/v281/photos/6/663228/3170288/1412150004-vi.jpg">
And the loose power connector you are looking two plug into that would look like one of the two bottom conenctors:
<img src="http://images16.fotki.com/v276/photos/6/663228/3170288/1210110703-vi.jpg">
Hope this helps!
