local b6 1.8t owners i need some help..
Part No: 8E0 909 518 AF
Component: 1.8L R4/5VT G 0003
Coding: 0016711
Shop #: WSC 79670
2 Faults Found:
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 001 - Upper Limit Exceeded
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0001
As for the physical cat detection, it depends on the station you go to... is the one you going to going to put your car on the lift and check? Some of the inspection places dont lift the car so it wont matter to them.
You should be fine if the code dont come back... dont worry about your cat worry about the code first.
