Full Road Force Balance...no more vibes even at 80 MPH or 60 MPH...
Old Sep 6, 2006 | 09:44 AM
paulroad's Avatar
Tech Guru
Default Full Road Force Balance...no more vibes even at 80 MPH or 60 MPH...
My local shop (MLS Tires in Freeport NY) has the Hunter unit. While he has done RFB for me on a single tire fdue to repairs, this is my first time MLS did all four and it was worth the $80.00.
Not only did he check the run out all are within .120, but after the balance phase, the RFB system then gave us the layout of which tire should be in which position as a result of their individual RF charactaristics.
My left front is now my right rear, my right rear is now my Left Rear, etc.
The simply are no vibes at any speed.
No appointment, less than 1 hour, and they even set their air gun to 89 Ft/LBS for me.
Old Sep 6, 2006 | 11:18 AM
BLKPERL's Avatar
Is that the same as corner balance?
Old Sep 6, 2006 | 12:23 PM
TighTT's Avatar
Default No..its a form of balancing wheels.
Much more accurate as it "feels" the imperfections across the tire tread and accounts for them.
Old Sep 6, 2006 | 01:38 PM
paulroad's Avatar
Tech Guru
Default Corner balance is an Old School (primarily trucks) methood.
Its done with the tires/wheels still on your car. You attach a counter balance ring assembly to the outside of the wheel and then a portable power wheel to your tire. The power wheel goes up to about 50MPH and then the vibes offset movable slides on the counter balance ring. Its 100% mechanical and works wonderfully on old rear drive non poistraction cars. It would most likely hurt any quattro, or Haldex system.
RFB actuall feels the tire surface and the roundness or out of round of the wheel.
Old Sep 6, 2006 | 01:58 PM
BLKPERL's Avatar
OK, Corner balance(Suspension), Road Balance(Wheel/Tires)
Old Sep 6, 2006 | 02:16 PM
paulroad's Avatar
Tech Guru
Default OH.. this is what you mean...
<ul><li><a href="http://images.google.com/imgres?imgurl=http://www.1300cc.com/howto/how2/corner/scale.jpg&amp;imgrefurl=http://www.1300cc.com/howto/how2/corner.htm&amp;h=298&amp;w=400&amp;sz=23&amp;hl=en &amp;start=1&amp;tbnid=praNq_zBMz_n4M:&amp;tbnh
Old Sep 6, 2006 | 06:47 PM
CTA4AVANT's Avatar
Banned
I had my ASA R1'S RFB and they still vibrate.....I think it might be the hubcentric spacers.
Old Sep 6, 2006 | 07:08 PM
paulroad's Avatar
Tech Guru
it can be spacers, the seat shape of the lugs, the torque of the lugs, etc.
 Pouria Savadkouei
 Michael S. Palmer
Quetzal
Wheels & Tires Discussion
Sep 23, 2015 07:50 PM
nyrobbie77
Sep 15, 2015 08:02 AM
Acuransx
A6 (C7 Platform) Discussion
Sep 14, 2015 12:43 PM
bilbo6209
14
Sep 4, 2015 01:57 PM
