Half way through the cv boot job - need advice!
I cut off the old boot, removed the triple square axles bolts and the axle is now free but there is not enough room to pull it down or to the side to remove the actual axle from the joint so I can slide the new boot on.
Do I have to remove the nut holding the axle on the outside and if so what kind of socket is this??
<img src="http://tomasz.data2net.org/gallery-albums/album104/Picture_013_Large.sized.jpg">
Or can I unbolt the whole arm assembly from the strut and drop it down (bolt in green)? Would that give me enough space to remove the axle joint (in blue)?
<img src="http://tomasz.data2net.org/gallery-albums/album104/Picture_015_Large.sized.jpg">
VW Golf 4, Polo, and New Beetle."<ul><li><a href="http://www.samstagsales.com/vwaudi.htm#axle">on this page anyways</a></li></ul>
