[xpost] my (on going) quest to solve brake heating problem...
Old Oct 11, 2006 | 11:05 PM
Wind-n-Water's Avatar
Default [xpost] my (on going) quest to solve brake heating problem...
<a href="https://forums.audiworld.com/brakes/msgs/1914.phtml"> //click to Brake Forum// </a>
We'll see how it does this wkend at Summit Pt. ;-)
Old Oct 12, 2006 | 04:30 AM
absolutcq20v's Avatar
Reply'd with my worthless input. Have fun this w/e!!
Old Oct 12, 2006 | 05:00 AM
4Rings::G2 boosted::'s Avatar
Banned
Default Interesting solution, that should help somewhat
I do like the airscoop mod though, might have to try that sometime
Old Oct 12, 2006 | 05:24 AM
Another Drew's Avatar
Guest
Default Good idea to remove that splash shield. What pads have you run before?
Just curious if yor ran pads with a high operating temperature. Also, with the cool weather, you shouldn't see any fade problem if you're running the right pads.
Old Oct 12, 2006 | 06:13 AM
Jimax's Avatar
Default I really doubt the stock 1.8T brakes are all that good for track use
What's happening when you say you have brake fade? Are you getting good pedal pressure feel but not enough grab? Or is your brake pedal going to the floor after repeated high-speed stops? There is a difference and depending on which symptom you have will help determine the fix.
If your pedal pressure remains the same, but you're lacking the grab you need to get the car slowed down, then your pads/rotors are over heating. Your cheapest solution is to run a more aggressive pad. The more aggressive pad (Pagid Blacks, Hawk HPSs, or even all-out track pads) can withstand higher temperatures while still providing effective braking. Otherwise, you'll need to do a cheap upgrade to bigger rotors (like 3.0 rotors).
If your pedal goes to the floor, then you're over heating your fluid. That's easy. Flush out the OEM stuff and throw in a higher temperature fluid.
I ran my stock 3.0 brakes (well, I ran better pads), for three track events. Sure, the 3.0 brakes are bigger than the 1.8Ts, but they held up decently well for those three events. I've since outgrown that and have upgraded to B5 S4 front brakes (slightly larger rotor, dual-piston caliper) with aggressive street pads for the street and dedicated track pads for the track as well as aggressive street pads in the back, along with SS lines, and Motul 600 fluid. The upgrade was cheap ($350). If you're going to continue tracking your car, you may want to consider making a wise investment in a better brake solution.
But as others have said, upgrade the cheaper componenents first to see if that takes care of your problem. Pads are your biggest bang for the buck.
Old Oct 12, 2006 | 07:18 AM
genxguy:gettingclose's Avatar
Member
Default You could paint the Altoid cover white or silver, so it reflects heat away from the sensor.
Are Audi 1.8T brakes 11" or 12.3"? 12.3" is what I have, and it's just right for my 3000lb car, I think... Could a bit bigger for some of the higher speed straights. So if your 3600lb car is running same or smaller rotors, I can see why they'd overheat.
Old Oct 12, 2006 | 06:22 PM
Default ... background & history of what was tried
<a href="https://forums.audiworld.com/brakes/msgs/1917.phtml">// xposted over at the brake forum //</a>
N'Syncro
33
Feb 16, 2020 03:12 PM
Tom10
Audi A3 / S3 / RS 3
10
Jul 8, 2018 09:30 AM
dorschman
Sep 17, 2015 03:24 PM
alin.zalau
Q7 MK 1 Discussion
Sep 12, 2015 01:09 PM
ajg617
Sep 6, 2015 07:23 AM
