Paging Roger@CapitalAudi...
Old Oct 12, 2006 | 11:36 AM
OLight:TNG's Avatar
Default Paging Roger@CapitalAudi...
OK, I need an authoritative answer to a question for the car listed below:
Apparently, 2 possible rear rotor sizes. Build label says 1KD, not 1KP.
Does that mean Audi was kind enough to put 1.8T rear rotors (245x10mm) on my 3.0 Avant? (A car, I might add, more likely to have a heavier load over the rear...)
Will existing calipers & 15" wheels fit if I just buy the "1KP" 255x12mm rotors?
thanks...
Old Oct 12, 2006 | 11:43 AM
apk-S4's Avatar
Whoa...that's an interesting twist. Keep me updated.
Old Oct 12, 2006 | 03:13 PM
Roger @ CA's Avatar
Default Well, easiest way to check is get the size or part number off your current rotors...
The 2002 A4 3.0 is definitely 255x12mm rotors in the rear. Are you sure you have 15's? hit me up with your VIN and I can look further.
Old Oct 16, 2006 | 06:19 AM
OLight:TNG's Avatar
Default VIN to check...
WAUVT68E22A251077
And you're right - I have 16" rims. I'm used to 16" being the plus-1 size from my old car.
I'd appreciate the check - I'd have to wait until tomorrow to take a wheel off and measure (or find a part number), and I'd love to order my parts today!
Thanks!
Old Oct 16, 2006 | 01:40 PM
Roger @ CA's Avatar
Default Yep, you have the bigger ones...
8E0 615 601Q rotors and 8E0 698 451E pads.
Old Oct 17, 2006 | 10:03 AM
OLight:TNG's Avatar
See that, APK? Roger says I have the bigger ones.
Old Oct 17, 2006 | 10:13 AM
apk-S4's Avatar
no comment and I suggest you keep your personal affairs to yourself.
Mesa512
S4 (B8 Platform) Discussion
20
Jul 7, 2018 11:23 AM
A6GT
A6 (C7 Platform) Discussion
17
Dec 29, 2016 08:15 AM
Monsoonenough
Oct 3, 2015 02:59 PM
beep-beep
Audi A3 / S3 / RS 3
Sep 24, 2015 02:25 PM
