Tony....my window is fixed...I wouldn't have been able to do it without watching you dismantle my
Old Oct 22, 2006 | 02:40 PM
Felk_2.7T's Avatar
Default Tony....my window is fixed...I wouldn't have been able to do it without watching you dismantle my
door last week....thanks for the instruction, now the window works and all is good...
Old Oct 22, 2006 | 05:01 PM
absolutcq20v's Avatar
Awesome! Mine's behaved since then, let's hope it continues...otherwise I'll see you soon. :P
Old Oct 22, 2006 | 05:21 PM
Felk_2.7T's Avatar
Default I picked up an extra set of glides (or whatever they're called) for my driver side window...if you
do your window let me know...we'll knock your's and mine out together...
FYI: Bentley says to remove the regulator you need to drill out the rivets...what a PITA...after burning up one of my drills and getting a bit stuck, I wised up and pulled out my dremel with the diamond cut off wheel...sparks were flying but it worked like a champ...
Old Oct 22, 2006 | 05:56 PM
Mat Indukts Lambos's Avatar
Banned
A6 window guides, eh? You're doing both when you do it, right?
Old Oct 22, 2006 | 06:40 PM
Felk_2.7T's Avatar
Default Both??? do you mean the two in each window or both windows???...I replaced my window regulator for
the front passenger window this weekend and picked up an extra set of guides for the driver side window...driver side runs fine, but I have the set to swap out if or when they go bad...
Old Oct 22, 2006 | 10:44 PM
Banned
both guides for one window.
Quick Cal
4.2 V8 Discussion
Jun 25, 2018 07:57 AM
ByByBMW
A6 (C7 Platform) Discussion
23
Jan 27, 2016 09:58 AM
lbennett12
Sep 27, 2015 09:18 AM
NYCtt123
Sep 27, 2015 05:04 AM
Bruce B
Q5/SQ5 MKI (8R) Discussion
Sep 25, 2015 12:11 AM
