S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
How do you adjust the height/distance of the stock muffler tips?
Old Mar 4, 2005 | 05:42 PM
DiscerningInfusco's Avatar
Elder Member
Default How do you adjust the height/distance of the stock muffler tips?
In other words, how do you change the height between the muffler tip and the valence?
Old Mar 4, 2005 | 06:21 PM
Pete @ Stratmosphere's Avatar
Former Vendor
Default You would have to bend the OEM hangars DOWN at...
the rear mufflers. With an aftermarket system like Milltek you can control height with muffler rotation and centering (like OEM). -Pete, Stratmosphere
Old Mar 4, 2005 | 06:27 PM
DrGP's Avatar
Banned
Default How dificult is that to do, and what tools would you recommend?d
I had Audi adjust mine a few weeks ago and I still think that they are too low. I am familiar with the metal extension on the muffler that engages the rubber hanger. I presume that you would bend this extension?
Old Mar 4, 2005 | 06:52 PM
Former Vendor
Default A big freakin' hammer, but seriously...
I need to look more closely at the OEM system. Pretty beefy. Heat could help too. I think they are a "Y" and they may get wider if you pound them but that could do the trick too. Binding up the hangars is not what I would prefer (pinching them). -Pete
Old Mar 4, 2005 | 07:02 PM
DrGP's Avatar
Banned
The stock hangers are rubber, so you would need to bend the metal extension on the muffler
Old Mar 4, 2005 | 07:03 PM
Elder Member
Default ****... that's not good.... one of my tips is lower than the other.... and I'm not sure why...
I got the car about two weeks ago... and there was some minor 'lot damage' to the bumper.... but putting things together, seems like it was a bit more... I'll have to get on my back tomorrow when i pick her up and see what's under her. Damnit... won't sleep tonight....
Old Mar 4, 2005 | 07:09 PM
DrGP's Avatar
Banned
Default LIKE THIS? I had Audi straighten mine out last month. BUT
<center><img src="http://pictureposter.audiworld.com/53054/tail_pipe.jpg"></center><p>I stll think thay are about 1/4-1/2 " too low
Old Mar 4, 2005 | 07:10 PM
DrGP's Avatar
Banned
BTW, Audi can fix it easily! Sleep well.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 4, 2005 | 08:50 PM
Elder Member
Yes sir... I hope soo... I will have to bitch and moan probably... but... hey it's worth a try....
Old Mar 5, 2005 | 01:26 PM
oatzel's Avatar
Elder Member
Default you could try loosening the back of the system from the dps, should be 4 17mm bolts
near the center resonator, and then try to move the system around a bit. that's probably what they did with Dr. GP's to fix his.
it's really a tilt more than anything as the tip that is higher will move lower as you lift the other one.
definitely easier with 2 people
loosen. level. hold. tighten bolts
ECS Tuning-Audi
Q5/SQ5 MKI (8R) Discussion
11
Feb 24, 2023 12:58 AM
Cmmartin23
26
Aug 23, 2016 04:44 PM
Zerka
Sep 21, 2015 10:18 AM
audiavant04
Sep 15, 2015 09:51 AM
