1995 B5 1.8 Idling problems
Old Jun 12, 2004 | 07:42 AM
bazz's Avatar
New Member
Default 1995 B5 1.8 Idling problems
After I accelerate, my revs occasionally fluctuate at idle from 500-800 RPM (at the traffic lights) causing major vibrations. It fluctuates for 3 secs then settles.
Can anybody help me out?
Thanks
Old Jun 12, 2004 | 02:59 PM
AUDIOZ A4's Avatar
MAF?
Old Jun 12, 2004 | 03:06 PM
STASIK_A4's Avatar
My 96 does the same thing..... but it does when ever it feels like not all the time....
Old Jun 12, 2004 | 03:26 PM
tur-80's Avatar
New Member
Default My 98 B5 VW Passat (1.8T) does the same thing...
with the A/C on the idle quickly drops to about 700rpm then bounces back up. With the A/C off the idle slowly drops back to 850rpm (normal). So I took the car to the dealer and they said that was normal. They said it has something to do with the A/C compressor being turned off when the accelerator is pushed (I thought this only happened under WOT) but it turns back on when you release the accelerator. Personally I think it has something to do with the throttle body motor that controls the idle.
When you take your foot off the accelerator in my wife's Golf GTi (1.8T) it slowly drops back to idle speed regardless of whether the A/C is on or off. I can't see why this couldn't be done regardless of whether the A/C was turned on or off with the B5 1.8T.
Old Jun 13, 2004 | 06:10 PM
bazz's Avatar
New Member
Default Re: My 98 B5 VW Passat (1.8T) does the same thing...
Thanks for that! I'm intending to take it to the Audi dealer to get it checked out soon.
Old Jun 13, 2004 | 06:33 PM
Lucas_Gchips's Avatar
Try changing the spark plugs for a quick check
Old Jun 14, 2004 | 01:38 AM
ea2oo1's Avatar
New Member
Default Re: 1995 B5 1.8 Idling problems
Either an air leak or non calibrated/faulty throttle body. Try to check for codes and do a throttle body adaptation.
ChulaaSoYUM
Oct 27, 2015 09:00 AM
Brandsman
Feb 7, 2006 11:50 AM
Crazycamp
Dec 29, 2003 02:26 PM
pumbaadpig
Feb 1, 2001 03:28 AM
pumbaadpig
Jan 30, 2001 08:44 PM
