2000 A4 Turbo Timer
Unfortunately, i hate the fact that you can't arm the car with a remote while it's running, so i disabled the timer for now until i can get past that.
If you turn off the car and pull out the key really quickly, does it work? For my quick attempt, the signal wire that i'm using seems to shut off after the engine one shuts off, so i need to pull out the key quick enough(to get them to loose power at about the same time) so the timer gets the signal in time to keep the car running.
Like I said, it's a quick attempt, so I will need to dig on the wiring diagram a bit more to get this to work properly.
