New 06 A4 2.0T w/tip vibration
At higher speeds, we also have that "all-over" vibration that you described... through the floorboards, etc. We just bought the car not quite two weeks ago.
I want to get this figured out because it is very annoying and should not be happening.
I'm thinking the wheels are grossly out-of-balance -- so much that dynamic road-force balancing won't help 100%. Our dealer is going to work with us on this... I'll post any updates here.
Sorry your problem seems worse, but fight the good fight, I don't think Audi wants unhappy customers as they have set their goal in the US to equal or best BMW in sales. Quite a reach, but that's their goal. Good luck!!
The dealer has been cool about it but they have been concentarting on the wheel/tire combo and road force values. They changed me from Pirellis to Contis and with the RF values around 5-7 it seems about 90% better but it's still there. It starts around 53-57 mph for the steering wheel shakes and above that for the entire car shakes.
They were able to identify the same issue on nearly every A4 on their lot so we're not alone. I have put in for a lemon law buyout because of the time and amount of visits I have had for this issue.
I love the car minus this issue but if Audi doesn't step it up I am going back to BMW.
Eric
Apparently, they (Audi) started using a silicone-based lube that makes it easier to mount the tires onto the wheels. Well, this silicone stuff is pretty slick. As a result, the tire actually moves around the wheel as you drive. They can road-force balance until they're blue in the face, but the vibrations will always return.
This can happen after driving only a mile or two following a re-balance. Thus, if the tire moves in this manner, it pretty much renders the road-force balancing useless.
If you guys just bought your cars, you should not be charged for this work. This will likely make it to a TSB.
This makes sense now... As we drove down the highway, we felt the vibes come and go. If the tire was actually moving around the wheel, each time it makes a complete rotation, everything goes in and out of balance.
