A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Sirius Tuner Removed, CD's not working
Old Jan 14, 2007 | 10:24 AM
nickel4490's Avatar
Default Sirius Tuner Removed, CD's not working
Sup Everyone...
My service for Sirius ended and I did not renew it since I don't use it. As a result, I removed the Sirius unit from the trunk. After removing, my RNS-E works fine and the AM/FM works, but no sound is coming from the CD changer. The screen shows that the CD is playing (since the time is counting), but there is absolutely no sound. FYI, I didn't do anything with the cables to the Satellite Tuner (meaning I just left them alone after disconnect). Anyone have a clue how I can fix this? I know I can plug the Sirus unit back in, but I wanted to sell it so I can add a DVD player to my NAV+. Please help!
Thanks,
Jeff
Old Jan 14, 2007 | 01:08 PM
DaveJJ's Avatar
New Member
Default I'm curious too
I'm curious on this too. My friend with a 330i removed his Sirius and had the same problem. He just put it back and now it's fine but still curious.
Old Jan 14, 2007 | 02:23 PM
goku's Avatar
Member
how much do you want for the Sirius unit?
Old Jan 14, 2007 | 02:34 PM
Aarononymous's Avatar
Default If I remember correctly there is a loop harness installed before Siruis module was installed...
Also there is a connector behind the kick panel by the front pass. floor that gets connected on install. Lastly if I remember correctly coding has to be changed. I haven't installed a Sat Radio in awhile...I'll check it out...
Old Jan 14, 2007 | 04:32 PM
nickel4490's Avatar
Default Re: how much do you want for the Sirius unit?
Ummmm, let me see if I can get this loopback adapter. If I can't find it, then I'm not going to sell it....
Now that I think about it, when you install the unit, you will have a loopback adapter which you will not need. If you want to make a trade of $$$+loopback adapter for the Sirius tuner, please send me a PM.
Thanks,
Jeff
Old Jan 14, 2007 | 04:38 PM
nickel4490's Avatar
Default You are 100% right.....
....There are two steps that need to be completed in order to remove the satellite tuner and still have sound from the CD Changer.
1. Install a loopback adapter
2. Switch the CAN bus to the correct connector (1 connector space to the left) .
Here is a link for this stuff....
<a href="http://www.navplus.us/forum/viewtopic.php?highlight=sat+connector&t=3933">No Sound from CD-Changer after Sirius Tuner removed Solution</a>
The question I have is what is the part number for the loopback adapter???? I am new to this stuff so I am hesitant about making one.
Thanks,
Jeff
JeffW
Dec 22, 2005 06:33 PM
Kingttr
Apr 30, 2005 08:50 AM
DFWKSIG
10
Oct 25, 2004 08:20 AM
GlenC
15
Dec 31, 2003 02:37 PM
mshan
Mar 13, 1999 07:53 PM
