My first problem with my S5. CEL came on...
After the scan we found this::
Click the link to see what Ross-tech makes of this code.
1 Fault Found:
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 008 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 2
Fault Frequency: 6
Mileage: 27657 km
Time Indication: 0
Date: 2009.01.31
Time: 13:34:21
Freeze Frame:
RPM: 1998 /min
Load: 15.7 %
Speed: 46.0 km/h
Temperature: 42.0°C
Temperature: 1.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.859 V
Readiness: 0000 0000
My guess is the fuel pump is on the fritz and will be replaced. I'll keep you all posted when I learn more.
It was a sad sight watching the car being taken away on a flatbed this morning!
Also, when driving the car last night I noticed that when accelerating there was very abrupt changes in the amount of power and how smooth it was. (like the engine wasn't getting enough fuel) I would compare it to the variation in power people have talked about when you go through 2500-3000 rpms but much more noticeable.<ul><li><a href="http://wiki.ross-tech.com/index.php/P310B/012555">http://wiki.ross-tech.com/index.php/P310B/012555</a</li></ul>
Now i need to somehow get myself to the dealer to pick it up...
