Koni coilovers
Old Mar 19, 2009 | 03:46 PM
seinsmeld13's Avatar
Default Koni coilovers
I am having Koni coilovers installed next week. I need your input as to what else you guys would recommend doing at the same time with respect to the suspension. If I lower the minimum 25mm do I need a camber kit/rear control arms?
My car is an 05 TT 225hp
Old Mar 19, 2009 | 04:02 PM
MikekiM@PureMS's Avatar
Former Vendor
You'll want new front upper strut bearings/bushings.
With a minimal lowering, there's a chance you won't need any adjustment in the rear. It's a close call.
Strut Bushing/Bearing Kit
Old Mar 19, 2009 | 05:10 PM
hahnmgh63's Avatar
Default New parts needed
Yes, the upper strut bearings are needed, and you can get away without a camber correction for a couple of thousand miles but you will eventually need a camber correction. I have had the Koni coilover kit on my car for the last few thousand miles and I have the camber correction kit but I haven't installed it yet, but will soon, and I'll probably do all of the rest of the suspension bushings at the same time.
Old Mar 19, 2009 | 05:53 PM
Silvr_Surfr's Avatar
Member
Default Get a set of k-mac adjustable bushings for the control arms. At
least a 1/2 set, but might as well get a full set for both lower and upper arms. If you decide to go lower than an inch you may have issues with toe and may need the extra adjustability. I'm dropped a smidge over 1.25" on koni coils and I decided to run a full set of k-macs just in case. Don't know if the alignment guy needed all four but he hit my specs dead-on.
Oh, and you might as well put a larger rear sway bar in while you're there =] I have a 19mm neuspeed.
Old Mar 19, 2009 | 08:15 PM
DumpTTruck's Avatar
I'm down a bit more than an inch and my front camber is conservative with the stock adjustment. Or were you talking about the rear? I personally like the adjustable arms more than the KMACs
Old Mar 19, 2009 | 08:33 PM
hahnmgh63's Avatar
Default Yea, the Kmacs in the rear. I have the 1/2 set. 1.5" lower than stock.
The 1/2 KMACS are doing fine, I'm not planning on going any lower than 1.5" from stock.
Old Mar 20, 2009 | 08:09 AM
Member
Default Sorry, I thought you were asking about
possible camber issues in the rear. I don't have anything for camber correction in the front.
Old Mar 20, 2009 | 10:27 AM
DumpTTruck's Avatar
The lower ball joint has a fair bit of adjustment. The really slammed guys use extended plates. (you'll likely be seeing more of those here....)
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 20, 2009 | 07:24 PM
thanks guys for your help, I am going to use the full Kmac, I'll post photos when done
SilverBullet12
Q5/SQ5 MKI (8R) Discussion
Feb 22, 2017 09:51 AM
HugeTTs
Feb 16, 2009 01:15 AM
marksk1
23
Feb 10, 2007 05:24 AM
esporque
Feb 1, 2007 10:33 AM
ttuner333
Apr 1, 2006 06:06 PM
