Help! why is my timing belt suddenly off a tooth?...
I checked the timing markers and they are off by at least 1 tooth, how did that happen?
I changed the belt over 2 years and almost 30K miles ago with no problems until about a month ago. What could possibly cause the belt to jump a tooth? and would it be ok to just move it a notch without taking everything apart?
thanks
Belts do skip. It's rare but not impossible. When you did the belt I assume you did the tensioner and water pump also?
Yes, I replaced everything, tensioner, waterpump, idler pulley, thermostat etc.
I am just having a hard time understanding how it can physically skip.
I thought about just compressing the tensioner and moving the cam gear to where it should be but the more I think about it, maybe I should just do the whole job over again
If it was me and I was sure that the timing belt had skipped I would first off offer my first born up for sacrifice because it only skipped one tooth and didn't write off the entire top end of the engine. I would then purchase a new timing belt and install it.
