Oil Pressure problem (help)....
Old Mar 28, 2009 | 06:09 AM
Vanimaniac's Avatar
Member
Default Oil Pressure problem (help)....
Hey guys. Yesterday, I was trying to back the Audi out of some icy/slush mix. It took a little effort but I got it out. But as I was driving off, the "Oil Pressure" light came on. I stopped and checked the level. Topped it off thinking that may help. No oil drips on the ground or where I was parked before. Could it be that there is a sensor somewhere down low that got messed up as I pulled out of the crust? This is the first time this light has ever come on.
I'm going to jack it up. What should I look for?
Thanks!
Van
Old Mar 28, 2009 | 06:19 AM
Autobahn Wrench's Avatar
Default some things to look at
There is a level sensor in the bottom of the oil pan, which is easy to see with the belly pan off. I would check the wiring, which is a favorite for animals to eat. If the wiring is all good, it might be the sensor itself.
Another possibility is the oil pressure sensor on the oil cooler. If you have a vag-com, you can check the oil pressure in the measuring blocks of the interment cluster. I think it is block 4, but do not quote me on that.
Good luck, Van.
Old Mar 28, 2009 | 06:45 AM
Vanimaniac's Avatar
Member
I'll check when it warms up a little outside. It's the dreaded red symbol though.
Anybody with a Vag in the Arvada area want a free six pack of your choice?
Thanks!
Van
Old Mar 28, 2009 | 02:32 PM
ar design's Avatar
I may be in the area a bit later, I can bring my cable. Give me a call if you want 303 990 3612
Old Mar 29, 2009 | 05:11 PM
Vanimaniac's Avatar
Member
Doh. Just checked this post. Let me know if you are going to be around in the area in the next few days.
Thanks!
Van
Juxhinriza
Jan 6, 2018 03:32 PM
ay6
Sep 11, 2015 03:47 PM
mpoo83
13
Oct 9, 2011 05:45 PM
evilEE
Sep 14, 2011 07:31 AM
Libtek13
Aug 4, 2004 09:45 AM
