99 A6 Avant Engine Swap
The 2.8 is a proven reliable engine. The 3.0 is not as rebust (IMHO) nor is it anything that even resembles a direct fit into your car. Find a used 2.8 out of a 98 or 99 A6 and install it. It should not be too hard to find one; most of them last forever.
Make sure you do a complete timing belt service on anything you install, including the cam seals, crank seal, cam adjuster seal, water pump, yada, yada (STFA)
...and check your oil more often ;-)
call or email we can discuss things, mind you motor has 89k miles but it is in very good condition only needing the TB and seals replaced before shoving her back in
Conrad
antioch,ca
email me at rotarysss@sbcglobal.net
