ECU swapping compatibility
Old Apr 12, 2009 | 07:33 AM
pre-cbs's Avatar
Default ECU swapping compatibility
I was thinking about buying an out of state ECU that's been chipped. My ECU number is 8N096018K and it's number is 8N096018T. The guy says his is off an 01 225 roadster, mine is an 01 225 coupe. Does anyone know if they are compatible?
Old Apr 12, 2009 | 08:12 AM
XCLR8TT's Avatar
Senior Member
It won't work. The numbers have to match all the way to the final letter.
Old Apr 12, 2009 | 08:37 AM
pre-cbs's Avatar
bummer, this guy said his original ECU was 8N096018AT and he replaced it with this MTM chipped 8N096018T and it worked. any thoughts on why?
Old Apr 14, 2009 | 01:11 AM
Big turbo TT's Avatar
Sometimes files are compatible with one another.I have flashed cars using different # files for BT stuff when there wasn't a file available for a certain model.You don't know until you try,and it should be immo defeat as well.
Old Apr 14, 2009 | 01:13 AM
Wanted to add,I am not recommending this,more just stating there is a fairly good possibility it will work.
Old Apr 14, 2009 | 11:11 AM
pre-cbs's Avatar
thanks for all the info, I opted for a REVO flash instead. so far I like it
JayLAudi
Audi allroad
Oct 16, 2009 08:59 AM
ZForce
Sep 6, 2006 06:10 AM
1.8Tizzle
Aug 17, 2005 12:27 PM
PILL PUSHER
Audi allroad
Feb 24, 2004 03:56 PM
2001AWDFUN
Oct 15, 2003 05:22 AM
