About to buy an A6 2.7T Quattro
I am a n00b here so please be gental. I am selling my Mark VIII LSC and getting a 2.7T. I believe I found a good deal on an 03 with 60K on it for under 10 grand.
I had an 02 S4 a few years back when I worked at Audi so I am fairly familiar with the engine and drivetrain.
My questions are what should I look for? What are common issues these may have other then the throttle body boot and bypass valves? The car is an auto with all the options. I assume they have a timing belt and if so is it 60K that they are supposed to be changed at? If so what is the expected cost of the service?
Before I buy it though I do wana see if there is any other issues to look for.
As soon as I buy it I will get the 93 octane APR tune as well as the better diverter valves and the aluminum throttle body pipe. I learned from my S4 that with that chip the other stuff is mandatory LOL! I will also be installing some R8 18" replicas and am thinking about some lowering springs but since it will be a daily driver I dont want it to be harsh. I have a 500+ HP Cobra for the weekend to punish my kidneys
Any good springs you guys can reccomend? Also is there any other minor mods that make a nice difference? Sway bars worth the money? Bigger brakes? How are the stock brakes?
Sorry for so many questions everyone, I am a n00b though
Searching for timing belt has only told me its between $700-$2200 to replace and that it should be done sometime between 60,000-100,000 miles.
Was hoping to find a helpful Audi site but so far I cant seem to find one
As for common things, there are a variety of oil leaks that can be addressed by doing all the related seals with each timing belt, the ABS controllers go bad but can be rebuilt for $200, the front end components wear out at less than 100k miles, the AirBag controllers fail, and a few other things.
Front end components, like ball joints, bushings, end links and the like? Do they have rack and pinion steering?
Thanks for the input!
I cant seem to find a CAI, is the Audi box that good that aftermarket companies figure there is no room for improvement?
The stock air box works best. Search for "hot air intake"
Yes and no; not the plumbing, the electrical portion. Check out module master or bba reman.
Yup. Tie Rod ends, and control arms.
Since it will be a daily driver I wanted some performance and comfert but not at the cost of over priced parts and maintenence. I like the Audis because for the most part the parts are not very expensive (most are cheaper than my Lincoln)
Well I look foreward to getting the car and I will post some pics when I pick it up. Its silver with the light gray or silver interior. No dings or scratches and is box stock. As I said I will get an APR chip and exhaust right away as well as some nicer wheels. Nothing flashy but nicer then the stock flat face five spokes that it has. Besides, i may want to install a Brembo or Stop Tech brake kit so slightly larger wheels couldnt hurt.
Wonder if 235 is the widest tire I can fit without rubbing if I am gonna drop it 1.5"?
