wire color for brake pad light
Old Apr 14, 2009 | 08:45 AM
quicksilver 2.7's Avatar
Default wire color for brake pad light
Can anyone tell me the color of the brake pad warning light that leads to the instrument cluster? I want to ground it or cut it.
Old Apr 14, 2009 | 09:39 AM
Grapeking's Avatar
25 Year Member
Sounds like you are in over your head- that is NOT the way to approach things. Instead, why not simply fix the root cause issue?
Old Apr 14, 2009 | 10:01 AM
Boston Driver's Avatar
AudiWorld Expert
...like changing the brake pads?
Old Apr 14, 2009 | 05:02 PM
WOWDee's Avatar
Default HEHEHEHE! I've changed my pads & have still yet to trick the sensor .... next proj
that and a half dozen other things .....belly pan ..... horn .... bumper ... wow ... i better get busy and get off this stupid computer
Old Apr 15, 2009 | 05:23 AM
Press's Avatar
Fear the Miata!
cut the wire....it's red....8^)
Old Apr 15, 2009 | 05:58 AM
Default brake pad light
I did change the pads and light still on. Took wheels off and bypassed plug to brake pad. Light still on. Took the instrument cluster out and cleaned
the connections. the light went off. Went to Key Largo for a week-car sat- now the light is on again. I read Paul Waterloo article on cutting the wire to the light. He stated the wire is brown/black stripe on an a8. I want to know if it is the same color on my 2000 a6 2.7t. Just sa reply from PRESS- is it the red wire?
Old Apr 15, 2009 | 04:19 PM
Press's Avatar
Fear the Miata!
dont cut any wire....chances are you'll have other issues, take it to a good indie and get it checked out
Old Apr 16, 2009 | 04:57 AM
On that wire color issue-I solved the problem. Just grounded the two wires leading to the right wheel brake pad to the body. I guess I had a break in the wire somewhere in the harness.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 16, 2009 | 05:18 AM
MrMcKulit's Avatar
I have this same problem. I suspect there is a break in my wire too but have been too lazy to check recently. All my pads are new - front and back.
quicksilver 2.7
Jan 19, 2009 05:45 PM
Jim II
Aug 17, 2008 01:13 PM
Audiheavy
Feb 20, 2007 08:51 AM
allaudiguy
Sep 2, 2004 05:48 AM
PaulW
Nov 16, 2003 06:36 AM
