Slipping tranny
Old Apr 15, 2009 | 11:51 AM
1METALHFEAD's Avatar
Default Slipping tranny
Aight.. Surfed the search for about an hour now and am giving up.
My cousin has an A6 with the 4.2 auto, 2000.
Out of the blue it started to slip, was searching for gears and now is in limp mode. It slips less in limp mode. It happened suddenly so I am thinking it was electronic that went bad. We have a Vagcom on the way but I wanted to do some research with "experienced folks" to know what to look for. Ya know like what wires to look for that may have come loose. Just did the timing belt about 2 months ago. Suggestions?
Old Apr 15, 2009 | 02:19 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Check the fluid level.
Old Apr 15, 2009 | 04:17 PM
Press's Avatar
Fear the Miata!
vag com is your friend, check the fluid level also, if the trans fluid hasn't been changed, this is a common issue on the my 00
Old Apr 15, 2009 | 06:34 PM
He changed the filter so the fluid is right. I know that since it has been in limp mode that it is working better. But you are saying completely change the fluid? Suggestions on the service?
Old Apr 15, 2009 | 07:58 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Please post in the correct place in the thread.
[QUOTE=1METALHFEAD;23767360]He changed the filter so the fluid is right. /QUOTE]
I trust no one but myself. How do you know that the fluid level is correct?
Old Apr 19, 2009 | 06:06 PM
Because I told him how to do it
Old Apr 20, 2009 | 02:57 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Clearly, step one is a recheck the level.
Old Apr 20, 2009 | 05:08 AM
jbchinoca's Avatar
As others have said, check fluid level first, make sure correct fluid was used, cannot use anything other than Audi fluid, then check for codes. Mine was done also, but the Audi dealer (who shall remain nameless but they were owned by last years LMP2 factoryPorsche team) messed up the first time and had to re-do the whole job. It was in limp mode sitting in their driveway supposedly ready to pick up. Hair raising experience to say the least.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 20, 2009 | 07:36 AM
The slipping and such actually started before he did the oil change and all. But I will make sure he double checks the fluid again.
beep-beep
Oct 31, 2010 09:40 PM
kidTwist
Oct 31, 2009 07:22 PM
Reifle
Feb 5, 2008 12:03 PM
snowcat
Feb 13, 2004 08:20 PM
J-byrd
Sep 22, 2003 06:14 AM
