HOW TO HELP!! REMOVINGand CHANGING TAIL LIGHTS.
Old Apr 25, 2009 | 07:21 PM
elf888's Avatar
Default HOW TO HELP!! REMOVINGand CHANGING TAIL LIGHTS.
Can anybody please provide a step by step with photo?
Thanks.
Old Apr 25, 2009 | 10:55 PM
TTmini's Avatar
Junior Member
those are NICE!! where did you get them and how much?
Old Apr 26, 2009 | 02:50 AM
elf888's Avatar
http://www.xtralights.com/index.asp?...ROD&ProdID=153
Old Apr 26, 2009 | 03:52 AM
Gray_TT_2003's Avatar
Junior Member
I don't have a step by step with pictures, but its actually very simple. There are two hand screws holding the inside, towards the middle, part of the tail light.
Open your trunk, and you will see little doors of the side of your trunk. One on each side. You just pop them open, inside you will fell and hand screw and undo both of them. You can also use a flash light to look in to find them. You will also have to disconnect the cable, but again just look for it. From there push straight out, use one hand from behind and one to steady to tail light. It will pop off the other mounts.
Installation is just the reverse, pop them into place and screw them back on.
Hope this helps
Old Apr 27, 2009 | 01:16 AM
DefianTT's Avatar
http://www.wak-tt.com/tt_bulbs/changingbulbs.htm
Old Feb 23, 2010 | 09:53 PM
yoho's Avatar
Default Tail lights
I have a TT. Earlier today I parked,got out of the car and set the alarm. The headlights were out but the tail lights and dashboard lights stayed on. Checked to make sure the trunk and doors were shut, still could not get the tail lights or dashboard lights to go out. Can anyone help?
Old Feb 24, 2010 | 03:31 PM
Python021's Avatar
your front parking lights are out, and the light switch is set to parkings light?
NyukNyuk
Mar 25, 2009 01:35 PM
maru
Jun 12, 2005 12:28 PM
AxeYrCat
Jul 17, 2003 04:21 AM
ironbanger2
Misc. Models Discussion
Jan 28, 2001 11:52 AM
