19x8 et30 on 2.8 quattro avant
Old Apr 29, 2009 | 08:36 PM
acangialose's Avatar
New Member
Default 19x8 et30 on 2.8 quattro avant
I would like to put 19x8 et30 rs6 rims on my 99 2.8 quattro avant. The offset seems wide, should i worry about rubbing my fenders?
Your input is greatly appreciated.
Old Apr 30, 2009 | 02:38 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Why?
Old Apr 30, 2009 | 08:13 AM
New Member
I want to fill out the wells. I cannot stand my 16" stocks. They make the car body look huge in comparison. I do worry that the 19s will make it look "dubbed" which i dont want but i do want to make the wheels look more appropriate in ratio to the size of the car and fill out the wells. Any better advice?
Old Apr 30, 2009 | 09:07 AM
Boston Driver's Avatar
AudiWorld Expert
19" wheels will probably not help you. The smaller sidewall will have the visual effect of making the gap between the tire and the fender opening ("a/k/a gapina") even larger than before. If you are looking to "fill" the wheel wells more with tire, you also run the risk of being out of tolerance for odometer accuracy.
17" wheels are the "best" compromise between looks and functionality/practicality. It still gives you enough sidewall for protection from road hazards, give you a comfortable ride. 18" looks the best, but you sacrifice some ride quality, and the price of rubber jumps quite a bit from 17" tires. 19" will just be bone-jarring.
The other thing to consider is lowering the car if you hate the gapina, but then you are looking at some $$, plus some harsher ride quality.
Here are a couple of picutres to illustrate...
Stock A6 non-sport ride height with stock 16" wheels:
Same car and suspension with 18" wheels (and same outer diameter tires):
The gap between the tires and the fender opening are the same, but the 18" wheels, the car looks even more jacked up!!!
Old Apr 30, 2009 | 01:23 PM
New Member
ahh! you are right that looks terrible! thank you very much for your advice. i def dont have the $$ for sport suspension or coilovers. argh!
Winston Lawrence
Sep 25, 2018 04:39 AM
justincr250
Jan 26, 2014 04:49 PM
audi/s/scott
Oct 17, 2008 03:01 PM
DD_(in Germany)
11
May 1, 2008 04:05 AM
J.C.
Wheels & Tires Discussion
Jun 18, 1999 07:55 AM
