Stern Drivetrain Mounts all in stock!
Eliminate failures with the OE design like these.
Our new Stern Pro-Mounts feature a heavy duty case, replaceable bushings and a lifetime warranty!
Mounts are sold as a pair.
Stern Pro-Mount Transmission Mounts
Introducing the long awaited Stern Pro-Mount Transmission mounts. After months of testing to make sure they were engineered perfectly, they're now in stock!
Lbs v. mm
A unique engineered design allows this new mount to offer a progressive feel, eliminating vibrations at idle, but offering great control when needed. Medium durometer polyurethane provides a long lasting wear medium encased in a durable aircraft aluminum housing.
Features:
* Factory fitment
* Heavy duty durable design
* Progressive damping
* Completely serviceable
Stern Differential Flange Mounts
This kit is designed as a factory replacement bushing kit engineered to reduce differential movement which translates to more power to the wheels. High durometer polyurethane bushings are used to maximize control with precision aluminum sleeves for a perfect fit. Quick and easy installation makes this a great upgrade for performance enthusiasts.
Stern Differential Power Ring
This differential mount insert is part of the new Stern line of performance products for the Audi and VW vehicles. This insert is designed as an upgrade for the factory differential mount. It installs quickly and easily and helps prevent the common differential "clunk" associated with higher horsepower vehicles.
Stern Pro-Mount Motor Mounts
Differential Flange Bushing Kit
Stern Front Snub Mount
