anyone ever deal with a melted primary o2 sensor wire on the harness side.?..
Old Jan 21, 2010 | 07:38 AM
ChucktownS4's Avatar
Default anyone ever deal with a melted primary o2 sensor wire on the harness side.?..
so my primary bank 2 keeps throwing intermittent codes no matter which of the 3 sensors i put in....
Q is, i dont really want to splice in a section, has anyone ordered the pins to do it oem? if so any feedback?
i dont think the wires can be soldered for a splice because of the type of material the wire core is made out of...
i know the sensor is very very sensitive to connections/splices being 0.80v range etc
apparently my wire hit the manifold and is stiff in one section, any other ideas from people dealing with constant intermittent codes on one bank?
feed back would be great thanks guys
Old Jan 21, 2010 | 07:47 AM
complacentsee's Avatar
I would have to see it, I didn't think there was anything special about the wiring in the harness besides being a high temp insulation. Most of the harness I've delt with soldered just fine. Have you thought about tinning (small) sections of the wire and then using low temp solder butt connector.
Old Jan 21, 2010 | 07:52 AM
i did try to crimp one section of the wire with butt connectors, however same codes still.... i figured the voltage drop was affecting it maybe..
so you soldered one in fine huh hmm? i tried to solder a o2 sensor wire i had spliced for a universal sensor and it gave me hell "i have plenty of previous soldering experience btw lol"
shrugz.... i did buy a section of cut harness from the junk yard, was wondering if maybe i could put fresh pins in it possibly and tap it in the ecu plug/harness
maybe i need to invest in a adjustable temp iron and low temp solder?
Old Jan 21, 2010 | 08:28 AM
I haven't on O2 sensors. (EGT sensor issue) A good solder connection should have virtually no resistance add or voltage drop.
Did you use lots of flux, tinning, and then full soldering? Low temp is good for the electrical connection since it has more lead. Maybe use some high temp silver solder?
Old Jan 21, 2010 | 09:23 AM
yeah i basically used a one temp solder iron "cheapie" and some old radio shack solder, maybe that was the deal,
i guess i can acquire a low temp iron and retry
no flux was used...
Old Jan 21, 2010 | 09:54 AM
Ahh. just retry. Tin the leads first with lots of additional flux.
Old Jan 21, 2010 | 09:56 AM
will do... thanks for the info
Old Jan 23, 2010 | 12:18 AM
billdapart's Avatar
Default nope
O2 sensor wires are shielded, (meaning they have additional grounds in between the primary and secondary insulation layers), and cannot be repaired.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 22, 2021 | 09:51 PM
Arsen Bassenov's Avatar
Could anyone please tell the pinout? Mine melted completely, so I cut the connector out. I have 5 wires that need to go into my new 4 pin connector. Thank you!
85-4kq-girl
Oct 20, 2004 07:23 AM
|skolnick
12
Jan 28, 2004 10:05 AM
Maver|ck
Nov 23, 2003 01:14 PM
kruiserprod
Oct 31, 2003 06:11 AM
KaMaKaZieP -ALUMIN8-
Audi 100 / A6 (C4 Platform)
Aug 23, 2003 08:35 PM
