235/35/19 Nankang tire issue
So, do I need I need an alignment with new tires? All 4 tires are wearing out exactly the same way (small cup shapes all around the inside edge. It seems to me like just a crap tire, but I am wondering if you guys have had this issue. The car had no shakes or shimmies and drives perfectly straight. The car is not lowered either, it is stock height.
I don't want to waste extra money if these tires just wore out like they normally do. I have read other complaints about them being noisy and cupping, but I did not see anyone say they all cupped on the inside edge specifically.
By the way, these are Nankang Ultra Sport NS-II 235/35/19.
I don't know exactly, but I estimate that I got about 15-17,000 miles out of these, but that is to blow out stage. They still have good tread except the inside edge. The fronts are still driveable for awhile (cupping spots are not bald) and other than the edge the tread is still good.
Any advice? Do these cars even have camber adjustment?, and why would i need it if I did not lower the car or change suspension geometry. These tires are just a tad taller stock (maybe 1/2" or less). They may be a little wider too. I would have to pull up the specs again. They fit the car perfectly (as in the offset seams about the same as stock)
