Naked Garage Party involving slave and clutch
However, in order to have this party, I NEED instructions on a well done DIY on how to replace my clutch slave. I know this involves removing the tranny (not a stripper named Ed).
Does anyone know where I can find an excellent step by step set of instructions? I expect to buy a Bentley manual for my silver, topless rolling party... but need something with photos (PG rated) on how to 'git er done'.
OR, am i better off pimping this to a professional mechanic and 'dunking dollars'?
Thanks for you help!!
It is a very big project especially when you do not have a lift but it can be done, I have done it in my garage using jackstands.
The Bently is a MUST I would very carefully look over every step of the procedure to make sure that it is something that you are capable of doing in far less than ideal conditions.
A very well stocked tool box, engine support (Harbor freight has cheap ones, I made my own but would of bought one had I know how cheap they were) 4 big heavy duty jack stands that can get the car very high off the ground. Air tools are nice but not necessary.
I do not want to discourage you from doing it yourself but give you the reality of how difficult the job is. How much experience do you have working on cars and the TT in particular.
I appreciate your help...
And for the record, the garage is charging me $1500.00 for the labor, new clutch/pressure plate, slave, throw out, etc. That is the best deal i could find. The AUDI dealer wanted $2300! The shop is actually at VW Dealer...
I only worry if I need a new dual mass flywheel. I PRAY i dont! That thing is very expensive.
With your low miles you might not need a new flywheel but they do start to fail with well under 100k miles. I replaced mine with a steel single mass flywheel so I never have to worry about it again.
and BTW $1,500 is a great price
