Rear caliper question
Old Mar 22, 2011 | 12:29 PM
Beas's Avatar
Default Rear caliper question
I am installing pads and rotors on 01 TT Quattro 225 and have an interesting situation.When I used the rotor tool on passenger side the piston returned to the home position in the clockwise direction.When I used the same procedure on the driver side, the piston is very tight, is it just stuck or do I need to turn the piston in the counter clockwise direction.
Tom
Old Mar 22, 2011 | 05:36 PM
rumburak's Avatar
Same procedure either side. I believe your piston is just stuck.
Old Mar 22, 2011 | 06:08 PM
AudiMick's Avatar
Tom
If the pads are well worn, you might try unscrewing CCW the piston a little more and then retry CW.
The other way is to loosen the bleed screw and then try. However this would mean you would have to bleed the brakes (which you might already be planning to do if you are changing the fluid).
brettf
Mar 20, 2004 03:24 PM
computrtutr
9
Apr 17, 2003 09:21 AM
kokerj
Dec 17, 2002 05:51 AM
RippleChip
Nov 10, 2001 09:17 AM
booker
Jun 23, 2001 04:05 PM
