Help ASAP with rear brake replacement
Car is on jack stand as I type and I have not a clue what to do next.
Mister Bally I tried alittle pressure but not too much cause I thought I might break something.
Don't forget to measure new pad thickness.
Saturday,16,July,2011,17:48:16:57746
VCDS Version: Release 10.6.4 (x64)
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Control Module Part Number: 4E0 910 801 C HW: 4E0 907 801 A
Component and/or Version: EPB A32C0220 H02 0220
Software Coding: 0000532
Work Shop Code: WSC 08201 444 74977
VCID: 1F471ADBB72D
Fault Codes have been Erased
4 Faults Found:
02433 - Supply Voltage for Right Parking Brake Motor (V283)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 213
Mileage: 176232 km
Time Indication: 0
Date: 2011.07.16
Time: 17:38:41
Freeze Frame:
Voltage: 11.59 V
Count: 87
02596 - Rear Brake Pads Worn
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 213
Mileage: 176232 km
Time Indication: 0
Date: 2011.07.16
Time: 17:44:13
Freeze Frame:
Voltage: 12.53 V
Count: 60
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Time Indication: 0
Freeze Frame:
Voltage: 9.94 V
Count: 61
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 213
Mileage: 176232 km
Time Indication: 0
Date: 2011.07.16
Time: 17:38:41
Freeze Frame:
Voltage: 11.49 V
Count: 86
FWIW, last I looked I had one of those rear codes too I couldn't track down after a pad change and VAG COM reset and calibration, even though it all functions. The pad wear adaptation didn't stick the first time though, so after being sure the car had new miles on it I was going to check it on my next scan again.
I was pretty nervous and thought I just caused myself a pretty hefty repair bill.
